CONNECT9 is a complete solution for mobile computer connectivity. Six-slot card reader accommodates all popular memory cards and three-port USB hub enables connection of up to three devices. The compact and stylish design makes it a digital lifestyle smart solution. Memory slots are active allowing simultaneous or cross transfer data from different media cards. With dedicated ports for Micro SD and MM2, no memory card adapters are required. Full support for high capacity cards such as SDHC is built in.
CONNECT9 is powered directly from a USB port and doesn't require software installation. Hi-speed USB2.0 compatibility provides maximum operating speed of 480Mb/s for the card reader and three additional low power devices.
