Akasa smart & cool motherboard controlled fans provide an ideal solution for combining ultra quiet and performance computing. Crystal clear fan frame and distinctive emperor blue blades provides precise controlled cooling by utilizing the motherboard PWM feature. PWM is more accurate, energy saving and fully automatic way of controlling the fan speed (RPM). (compared to voltage regulation) PWM is widely available on all current Intel and AMD platform based motherboards and it enables ultra quiet acoustics during normal PC use and high performance cooling under high system load. Clever fans can be used on a CPU cooler as well as a chassis or radiator fans.
