Unleash the power of high speed memory card
- SuperSpeed USB 3.0 card reader
- SuperSpeed USB 3.0 port
- USB 2.0 HUB
- USB 3.0 card reader unleash the power of high speed memory card
- Four card-slots are active at the same time, allowing cross format data transfer
- USB 2.0 HUB with independent power design
- USB 3.0 port backwards compatible with USB 2.0
Spec
- Application 3.5" PC bay
- Memory card slots 5
- Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD) / Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) / Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) / 64GByte for SDXC - 32GByte for SDHC / M2 (Memory Stick Micro M2) / microSD (microSDHC, High Capacity)
- Interface Internal USB 2.0 motherboard connector, internal USB 3.0 motherboard connector, USB 3.0 A male connector, SATA connector, 4-Pin PSU molex connector
- Data transfer rate 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
- LED indication Power On, Card In & Data Transfer
- Power mode USB and 4-Pin PSU molex
- Supported OS Windows 2000 / XP / VISTA / 7
- Plug & Play Supported
- Product code AK-ICR-17
Internal USB 2.0 motherboard connector, internal USB 3.0 19 pins motherboard connector, USB 3.0 A male connector, SATA connector, 4-Pin PSU molex connector
