UV 12" cold cathode dual pack. Lights up your PC interior with bright UV light interact with UV reactive accessories to create unique visual effect. 4mm low power lights inside the clear acrylic tubes for protection. Low heat emissions and long life. Easy, tool free installation with double sided adhesive tapes.
- 2 UV cold cathode case lights
- Dual 12V inverter included
- On/off switch
- 4mm lo-power tube, only 3 watts
- Tool free installation
