Game like you mean it
Acer XF Series gaming monitors range from Full HD to WQHD resolutions, with aspect ratios from 16:9 up to mega-immersive Ultrawide 21:9. Add to that you get AMD® FreeSync™, a 144Hz2 refresh rate and a 1ms* response time, and you get the gaming you deserve.
Pixel Powered
Acer XF Series monitors are designed to push your pixels to the max. IPS1 technology2 provides wide views and enhanced colour with 100% sRGB colour gamut2. A rapid 144Hz refresh rate2 smooths out 2D action. Add the 1ms response time2 and you’ve got pixel power.
Smoothed gaming
Slide through your ride with AMD® FreeSync™. FreeSync™ technology eliminates screen tearing and minimises stuttering by syncing the display refresh rate with the frames output by your computer’s display card. PC gaming doesn’t get much smoother.
Vision protected
Gaming is eye-intensive, so we help protect yours. Acer EyeProtect is a suite of technologies that ensure your eyes aren’t the thing that gets beat. Acer Flicker-Less, Blue Light Filter, Low Dimming and ComfyView technologies combine to make your eyes feel fine.
All the right moves
Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed.
It’s easy being green
The entire XF line also has multiple green design certifications that attest to our commitment to producing products that are both great and green.
