The Veriton series is ready to meet various business needs. With a powerful processor and fast memory, serious performance is delivered. High manageability fuels business growth.
Designed for efficiency, the ventilated chassis helps keep your Veriton N running cooler, longer.
Ideal placement
Free up your workspace and work more effectively with the sturdy support of the VESA mount.
Easy internal access
Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools.
Kensington Security Slot
The Kensington Security Slot is an anti-theft system that allows for one end of a security cable to be locked into a reinforced hole on the device while the other end is attached to a stationary object for additional device security.
Keep a healthy PC
Know when components are not functioning properly and avoid system failures with the Acer System Health Indicator.
Strong on security
The hardware-level Trusted Platform Module is serious security for any business that is serious about security.
1 (total) / 0 (free) x CPU , SO-DIMM 260-pin , 1 PCIe x16 , 1 PCIe
4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x HDMI
