The Veriton 4 series is ready to meet various business needs. Powerful processors and fast memory deliver serious performance, while a premium software suite offers security and manageability to fuel business growth.
Designed for efficiency, the ventilated chassis helps keep your Veriton N running cooler, longer.
Ideal placement
Free up your workspace and work more effectively with the sturdy support of the VESA mount.
Easy internal access
Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools.
Kensington Security Slot
The Kensington Security Slot is an anti-theft system that allows for one end of a security cable to be locked into a reinforced hole on the device while the other end is attached to a stationary object for additional device security.
Keep a healthy PC
Know when components are not functioning properly and avoid system failures with the Acer System Health Indicator.
Strong on security
The hardware-level Trusted Platform Module is serious security for any business that is serious about security.
Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
19.2 cm x 20.4 cm x 3.32 cm
1.5 kg
Personal computer
Product Form Factor
Tiny
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Region: United Kingdom
Processor / Chipset
CPU
Intel Core i3 (6th Gen) 6100T
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics 530
Video Interfaces
VGA, HDMI, DisplayPort
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Slots
1 (total) / 0 (free) x CPU , SO-DIMM 260-pin , 1 PCIe x16 , 1 PCIe
4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x HDMI
VESA mounting kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
