Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room. The contrast ratio of the monitor is superior and the response is ultra-quick. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. Moreover, the monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options. Professional Series monitors are mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: This monitor is wall mountable, giving you clear views with more room.
Convincing
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional Series monitors. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
Prepared
Collaborating with others is faster and more productive when you have plenty of ports available. Professional Series monitors allow you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options.
Green focus
