Back
Monitors
Acer S242HLDbid 24" 1920x1080 1ms VGA DVI HDMI Monitor
Quicklinx:
CPD4WS00
Mfr#:
UM.FS2EE.D01
Back
Marketing description is not available.
Acer S242HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Environmental Standards
ENERGY STAR Qualified
MPR II, RoHS
Display Type
Energy Class
Class A
36 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mercury free, Acer Empowering Technology, 6-bit gamma
VGA , DVI-D (HDCP) , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+15
Flicker-free technology
Stand
1 x VGA cable - VGA to VGA
MPR II, RoHS
Input Voltage
25 W
Power Consumption (Typical)
26.1 Watt
Power Consumption Sleep
0.69 Watt
Power Consumption (Off Mode)
0.52 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
