Back
Monitors
Acer Predator XB252Qbmiprzx 24.5" 1920x1080 HDMI DP USB Gaming Mo
Quicklinx:
CPBWWS00
Mfr#:
UM.KX2EE.001
Back
Marketing description is not available.
Curved immersion
Get immersed in the world's greatest curved gaming display. Your gaming experience will never be the same again.
Super-smooth
Get the buttery-smooth gameplay you've dreamed of. NVIDIA G-SYNC eliminates screen tearing and minimises stuttering for legendary PC gaming.
Become a hunter
Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand.
Overclock
Boost your refresh rate up to 100Hz with built-in overclocking. Minimise motion blur and enjoy more frames per second.
Acer Predator XB252Q - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class A
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 240 Hz
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
Black, dark silver
55.789 cm x 26.831 cm x 50.587 cm
3.1 kg
Display Type
Energy Class
Class A
38 kWh
Diagonal Size
24.5"
3D Technology
Active
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
ErgoStand, Zero Frame, nVidia 3D Vision, NVIDIA Ultra Low Motion Blur Technology, Acer VisionCare
Black, dark silver
3.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , USB 3.0 upstream (Type B) , HDMI , 4 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Input Voltage
26 W
Power Consumption (Typical)
23 Watt
Power Consumption Sleep
0.46 Watt
Power Consumption (Off Mode)
0.43 Watt
