1 x DisplayPort cable - DisplayPort to DisplayPort
MPR II, TUV, VCCI, DDC-2B, NOM, CCC, FCC, DDC/CI, ISO 9241-307, WEEE, cTUVus, EAC, TUV Rheinland
Input Voltage
Power Consumption (On mode)
36 W
Power Consumption (Typical)
28 watt
Power Consumption Stand by
0.5 watt
Power Consumption Sleep
0.5 watt
Power Consumption (Off Mode)
0.45 watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 26.8 cm - height: 54.2 cm - weight: 6.31 kg , Without stand - width: 56.6 cm - depth: 6.1 cm - height: 33.5 cm - weight: 3.93 kg
