Designed specifically with gamers in mind, the Acer Predator 15 combines raw power, enduring performance and accomplished style to make it an outstanding gaming laptop.
Packing a range of features to take your gaming experience to new heights, the Acer Predator is built for intense gaming with slick, sharp visuals and smooth gameplay. It comes equipped with an eight-cell battery for prolonged battery life - just what you need for those prolonged gaming sessions.
The Predator laptop is powered by a 2.30GHz Intel Core i5 processor, with a 1TB hard drive and 128GB SSD capacity - ample room for storing all those essential files - as well as 16GB of RAM and NVIDIA GeForce GTX 970M graphics card for outstanding visuals.
Its innovative DoubleShot Pro lets you choose which applications use your bandwidth, allowing for reduced lag and running your wireless and wired connections simultaneously. Predator Dust Defender prevents dust from building up by alternating airflow directions, while you can swap in Predator FrostCore to keep your laptop cool even when the action heats up.
