Acer P5515 projector features high brightness and contrast ratio for showcasing vividly detailed text and images. DLP 3D ready and HDMI 3D capability make work presentations more convincing, and home entertainment more exciting.
1080p Full HD resolution and wide format sharpen your vision
Full HD offers exquisite display and 16:9 aspect ratio delivering wide format for more content.
DynamicBlack technology
DynamicBlack technology dramatically improves image contrast by using dynamic lamp power adjustment to analyze content frame by frame. Acer projectors feature this technology for vivid image quality and a high contrast ratio.
Acer ColorBoost 3D technology
Acer projectors present nature's true colors with Acer ColorBoost 3D technology for both 2D and 3D content. ColorBoost 3D has the ability to reduce brightness decay and color shift when displaying content through enhancing color brightness. At the same time, it compensates color saturation and color temperature.
Acer ColorSafe II technology
Acer projectors featuring ColorSafe II technology use dynamic RGB gain control to secure color fidelity, even after prolonged use.
Split screen for multitasking
Acer eDisplay Pro allows a maximum of four users to display their contents on screen at the same time, which is mighty powerful especially for business meeting or education. Picture that you're in a meeting, and four of your colleagues can simultaneously display four different reports from four devices to one screen. How convenient!
Built-in speaker
With a built-in speaker, Acer P5515 projector allows you to enjoy studio nuance and enhanced clearer sound without external speaker. No matter in meeting room or classroom, these projectors' sound effect satisfies audiences all the time.
4-corner correction
4-corner correction enables user to adjust distortion from any single corners. Even the projector is not placed in a proper position, the function makes correction process easy and time-saving.
Auto ceiling mount correction
When the projector is installed in the ceiling, auto ceiling mount correction can detect the projector position and automatically adjust the orientation of the image.
Acer P5515 - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Contrast Ratio
12000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
UHP 260 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
1 x VGA cable
Power Source
AC
AC 120/230 V
325 Watt
31.4 cm
22.3 cm
9.3 cm
2.5 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
