- 21.5" Display with Full HD resolution - Stunning colors - Connecting features - Ergonomic stand tilts from -5 to 25 degrees - Environmentally friendly
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by frame, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
Acer Eco-Display
As part of our commitment to sustainable operations and corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
Acer K222HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/407549
Energy Class
Class F
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
50.8 cm x 20.7 cm x 39.05 cm
3.1 kg
Microsoft Certification
Compatible with Windows 7
ISO9241-307, MPR II, TUV, GS
Display Type
Energy Class
Class F
29 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
110
Vertical Viewing Angle
85
Backlight Technology
LED backlight
Acer EcoDisplay, ComfyView, 72% NTSC colour gamut
50.8 cm x 20.7 cm x 39.05 cm - with stand
3.1 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.05 cm - weight: 3.1 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 2.7 kg
