The compact, chic-white Acer H5 series projector transforms your living room into a home theater via native 16:9 HD-ready projection, HDMI connectivity, brilliant color reproduction - and immersive stereoscopic 3D entertainment!
Native 720p (HD-ready) resolution sharpens movie details; true 24p frame rate preserves real film quality; and high brightness and contrast ratio project crystal-clear images. Wall-color compensation lets you project accurate images even on colored walls, and HDMI connectivity portrays brilliant games and entertainment in the comfort of your living room.
Immersive 3D visuals
Stereoscopic visuals add depth and feeling to games, movies and photographs. The H5 series projector is certified for leading 3D solutions. NVIDIA 3D Vision kits transform hundreds of PC games to full stereoscopic 3D, and DLP 3D ready kits with high refresh rates render a flicker-free 3D experience.
Acer H5380BD - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
17000:1 (dynamic)
Resolution
1280 x 720
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hours - normal mode , Up to 10000 hours - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Speakers
Speaker(s) - integrated
AC 120/230 V
31.4 cm x 22.3 cm x 9.3 cm
2.5 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Contrast Ratio
17000:1 (dynamic)
Image Size
68.6 cm - 762 cm
Projection Distance
1 m
Digital Zoom Factor
2x
Resolution
1280 x 720 (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
190 Watt
Bulb life cycle
ColorBoost II+ Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 16:10 aspect ratio support, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
Lens Aperture
F/2.5-2.67
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone 3.5 mm , 1 x serial RS-232
Carrying case, wireless remote control
1 x VGA cable
AC 120/230 V
31.4 cm
22.3 cm
9.3 cm
2.5 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
