Back
Monitors
Acer ET430K 43" 3840x2160 5ms HDMI DP Mini DP LED Monitor
Quicklinx:
DB0BWS00
Mfr#:
UM.ME0EE.010
Back
Marketing description is not available.
All for 4K
Once you've sat with a 4k screen, you'll never settle for less. With 4k you can see more, do more and enjoy beyond measure.
Impress with IPS
An IPS panel lets you view your monitor clearly at angles of up to 178° while maintaining the same level of high-quality color.
Speakers at the ready
Two speakers, directly built in to your monitor, save on desk space while still offering up a powerful listening experience.
Stand strong
Two thin, strong metal feet grace the bottom of the ET430K, holding the colossal screen aloft for all to admire.
True clarity in vivid colors
Color-enhancing, image-sharpening and eyecare technologies combine flawlessly in the ET430K display's 4k resolution.
Color depth in 10 Bit
To create images that appear smooth and realistic, a high color depth is needed. With the ET430K monitor, you have that.
AcerVisionCare
AcerVisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Acer ET430K - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class A
Energy Consumption per Year
100 kWh
Power Consumption (On mode)
69 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
White
96.6 cm x 24.3 cm x 65.3 cm
12.36 kg
MPR II
Display Type
Energy Class
Class A
100 kWh
Diagonal Size
43"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, 72% NTSC colour gamut
White
12.36 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , DisplayPort output , DisplayPort , Mini DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-3.5/+11.5
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x HDMI cable
MPR II
Input Voltage
AC 120/230 V
69 W
Power Consumption (Typical)
55 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
5 °C
35 °C
10 - 85% (non-condensing)
