Back
Monitors
Acer ET221Q 21.5" 1920x1080 4ms HDMI VGA LED Monitor
Quicklinx:
DPQGWS00
Mfr#:
UM.WE1EE.001
Back
Marketing description is not available.
Acer ET221Q - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/401133
Energy Class
Class F
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
16.8 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Display Type
Energy Class
Class F
31 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA 100 x 100 mm
16.8 W
16.8 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.45 Watt
