Shaping your viewing experience with a curved form factor that delivers the incredible.
See the difference
Cutting-edge tech features allow you to immerse yourself in extraordinary visuals.
Stay in the game
The ED3 ensures you can enjoy all your favorite games with AMD FreeSync compatibility.
Silky smooth visuals
With a rapid refresh rate, the Acer ED3 delivers ultra-smooth viewing with faster frame rendering and lower input lag.
High-speed response
Keep pace with the action as the rapid response time reduces ghosting and smearing for clearer, more precise images.
Care for your vision
Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Acer ED273 wmidx - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/397325
Energy Class
Class F
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
61.28 cm x 16.82 cm x 46.59 cm
MPR II
Display Type
Energy Class
Class F
44 kWh
Diagonal Size
27"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mercury free, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
White
61.28 cm x 16.82 cm x 46.59 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
MPR II
Input Voltage
30 W
26 kWh/1000h
Power Consumption (Typical)
38 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.28 cm - depth: 16.82 cm - height: 46.59 cm , Without stand - width: 61.28 cm - depth: 7.54 cm - height: 36.2 cm - weight: 3.72 kg
