Back
Monitors
Acer EB490QK 48.5" 3840x2160 4ms VGA HDMI Display Port LED Monito
Quicklinx:
DPP8WS00
Mfr#:
UM.SE0EE.001
Back
Marketing description is not available.
Big, Boundless Viewing
Bask in the bright, boundless view of your movie-like display as the cinema comes to life in your very own home.
Enjoy the View
Color-enhancing, image-sharpening and eyecare technologies combine flawlessly in vibrant 4K.
Acer EB490QK - LED monitor - 4K - 48.5"
LED-backlit LCD monitor - 48.5"
Energy Class
Class A+
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.27963 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
3xHDMI, VGA, DisplayPort
Screen Coating
Semi-glare
Voltage
110.85 cm x 8.1 cm x 64.13 cm
11.7 kg
MPR II, VCCI, NEMKO, CCC, FCC, DDC/CI, RoHS, ISO 9241-307, EAC, NOM-NYCE
Display Type
Energy Class
Class A+
82 kWh
Diagonal Size
48.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27963 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Semi-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), 10-bit gamma, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, 6-Axis Color Adjustments, Picture-in-Picture
110.85 cm x 8.1 cm x 64.13 cm - without stand
11.7 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
3 x HDMI , VGA , DisplayPort , Audio line-out
Mechanical
VESA Mounting Interface
400 x 200 mm
VESA interface support
1 x VGA cable , 1 x DisplayPort cable
Input Voltage
56 W
Power Consumption (Typical)
130 Watt
Power Consumption Stand by
450 mW
Power Consumption (Off Mode)
400 mW
Dimensions & Weight Details
With stand - weight: 12.1 kg
10 - 90%
