This monitors provide stunning image quality and sharp details. They also have color adjustment to meet high color accuracy. With the clear view provided by these monitors, you can work clearer and get the job done quicker.
These monitors provide stunning image quality and sharp details with FHD high resolution. These monitors also have 6-axis color adjustment to meet the highest standard in color accuracy. With the clear view provided by these monitors, you can see work clearer and get jobs done quicker.
Enhanced usability
These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ErgoStand that allows you to adjust the viewing angle for maximum comfort.
Eco-friendly
CB Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting.
Acer CB241HYbmdpr - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.1 cm x 21.7 cm x 37.6 cm
5.9 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
92.6
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, ComfyView, Zero Frame, Flicker-Less technology, Bluelight Filter
5.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 watt
VGA , DVI , DisplayPort
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
