VGA , DisplayPort , HDMI , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+25
Height Adjustment
120 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Austria, Germany
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V (50 - 60 Hz)
Power Consumption (On mode)
17 W
26 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.42 Watt
Power Consumption (Off Mode)
0.37 Watt
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 20.6 cm - height: 52.1 cm - weight: 10.2 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg
