Back
Monitors
Acer B247Y 23.8" 1920x1080 4ms VGA HDMI DP LED Monitor
Quicklinx:
DYJNWS00
Mfr#:
UM.QB7EE.008
Back
Marketing description is not available.
ZeroFrame design
The near bezelless design creates a more seamless look, allowing you to see more of what matters most: the screen.
A strong, ergonomic edge
Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice.
Built-in speaker
The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
A wide range of color
sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
Designed for accuracy
Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colors and sharper overall visuals.
Acer B247Y - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/352849
Energy Class
Class F
Power Consumption (On mode)
21.8 W
Microphone, USB 3.0 hub, FHD IR camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
54 cm x 19.3 cm x 45 cm
5.59 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
ISO 9241-307 Class 2
Display Type
Energy Class
Class F
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms
Vertical Refresh Rate
47 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, High Frame Rate Control (Hi-FRC), ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Adaptive-Sync technology, Acer VisionCare, 6-bit gamma, Acer BluelightShield technology, Acer ColorPlus technology
5.59 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , HDMI , Audio line-out , 3 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
21.8 W
21.8 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.39 Watt
Power Consumption (Off Mode)
0.27 Watt
Shipping Weight
8.07 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
