This series is ENERGY STAR, TCO, and EPEAT certified, reflecting Acer's commitment to the environment. It is made with 85% PCR and 5% ocean-bound plastic while using 100% recyclable paper packaging.
Absolute Immersion
Take productivity to the next level with 4K ultra-high definition resolution. Text, images, and more will be crisp and clear for a more enjoyable user experience.
Video Calls Made Easy
Make use of FHD IR webcam for all your Zoom calls and video conferencing needs. It also supports Windows Hello for quick and easy logins.
Flexible Adjustments
The ErgoStand design of this monitor allows the user to tilt, swivel, pivot, and adjust the height of your display with flexibility so you can find the best viewing angle.
Details Matter
Whether choosing photos or editing videos, the 90% DCI-P3 color coverage with up to 1.07 billion colors gives you more precise colors and enhanced color depth to bring out all the details of your work.
Protecting Your Eyes
This display comes equipped with Acer VisionCare eye-protecting technologies such as Acer BlueLightShield, Flickerless, Low-dimming, and ComfyView.
Acer B227Q bmiprzx - B7 Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
49 cm x 19.3 cm x 48.5 cm
4.78 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Bronze
Display Type
Energy Class
Class F
30 kWh
Diagonal Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
VGA , DisplayPort , HDMI , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
180
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable , 1 x VGA cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
21 W
19 kWh/1000h
Power Consumption (Typical)
13 Watt
Power Consumption Stand by
0.32 Watt
Power Consumption Sleep
0.32 Watt
Power Consumption (Off Mode)
0.23 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 49 cm - depth: 19.3 cm - height: 48.5 cm - weight: 4.78 kg , Without stand - width: 49 cm - depth: 6.5 cm - height: 29.5 cm - weight: 2.83 kg
