The Aspire R7 convertible design immerses you directly in content. This slim, high-performance PC features the great Ezel hinge, which brings your touchscreen within easy reach whichever way you use it.
The Ezel hinge works just right - it provides low resistance for converting the Aspire R7 into four modes with just one hand, and higher resistance so the touchscreen stays steady when you use it. Work with the Aspire R7 at your desk as a notebook, flick it into display mode for sharing, or use it as a pad for drawing.
Ezel mode
Ezel mode brings the touch display closer to you, so you don't have to reach across your desk to use it. Just pull the display up and out, where it can float over the keyboard. Having the display that much closer makes switching between touch control and typing that much easier.
Great sights and sounds
The Aspire R7 delivers awesome sights and sounds, in every mode. The Full HD display makes details stand out, and powerful speakers plus Dolby Digital Plus blast the acoustic power of your notebook. In addition, audio channels automatically reverse when switching modes, so stereo sound is always perfect.
Acer Aspire Pro Series R7-372T - 13.3" - Intel Core i7 - 6500U - 8 GB RAM - 128 GB SSD - UK
Notebook - flip-hinge design
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
