The Aspire R7 convertible design immerses you in content like never before. This slim, high-performance PC features the Ezel hinge, which brings your touchscreen within easy reach whichever way you use it.
Acer's innovative Ezel Aero Hinge features two separate hinge mechanisms that work together to allow seamless transition between six user modes. This fantastic hinge also keeps the display very stable when you use it for touch control.
Thin, light, and tough
The touchscreen and its back cover are encased in two slices of Corning Gorilla Glass 3 - which makes the top panel very tough, beautiful, and strikingly slender. At only 1 inch thin (17.95 mm) thin, the Aspire R 13 is a joy to pack and carry.
A pen for your thoughts
The Aspire R 13's touchscreen works perfectly with the Acer Active Pen, which uses Acer Hover Access technology to activate pop-up, tap-on menus. The result is a more intuitive writing experience that is also very convenient, fun and productive.
Visual delight
You can choose between a WQHD display with power-saving IGZO technology that delivers super-crisp images, or a full HD display with wide viewing angles (IPS technology) and optical clarity solutions. All models feature direct bonding (zero air gap) for a brighter, crisper display.
Cinematic surround sound
Immerse yourself in movies with dolby digital plus home theater - sound technology that is crafted to bring every movie to life and put you in the middle of the action.
Comfortable viewing
Corning's AR/ETC (antireflective and easy-to-clean) glass coating reduces screen glare and improves contrast, while also making it very easy to clean the screen. A built-in light sensor auto-adjusts brightness levels to further enhance eye comfort and power efficiency.
Great video conferencing
This laptop has dual-array microphones for noise-free voice communication. Acer Purified. Voice technology tracks the voice of the speaker as he or she moves around the room. The Aspire R 13 is also skype certified because it has all the high-quality hardware required for great audio and video chats.
Acer Aspire Pro Series R7-372T - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip-hinge design
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB LPDDR3
Storage
256 GB SSD
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
