The highly-portable Aspire One Cloudbook packs everything into a beautiful, clean, and fan-less design of just 14-inch.
Ready for Cortana
Cloudbook gives you a full-fledged Windows 10 experience. That means you get the new Cortana personal digital assistant with voice commands that use the built-in dual mics to help you get things done, hands-free.
Speed-boosted wireless networking
With your head in the cloud, you have a need for speed. Our Cloudbook has the latest wireless networking1 that supports faster-than-ever connection speeds. It makes your cloud storage speedy, your apps peppy and gives your browsing a big boost.
Office & OneDrive included
For a double dose of productivity, the Cloudbook comes with a personal 1-year subscription to the full version of Microsoft Office2, plus a place to put all your stuff - 1 TB of accessible-from-anywhere online storage with Microsoft OneDrive.
Thin and really light
Packing every feature you need into a beautiful, clean and simple design, the Cloudbook is just 17.9 mm1 thin. And at only 1.15 kg1, this flyweight laptop not only fits perfectly in your bag, it won't drag you down either, wherever you go.
Triple Storage
With the Cloudbook, you get built-in solid-state storage, expandable using the SD card slot. Then, there's 1 TB more in the cloud with Microsoft's OneDrive2. Plus, with our Build Your Own Cloud technology you can set up additional private cloud storage.
Clear as a bell
The Cloudbook doesn't forget about audio quality either. Its dual digital microphones produce clear online calls, so they'll hear you loud and clear, from anywhere. And of course its powerful speakers provide more realistic and lifelike sound.
