The 3M Ergonomic Mouse has earned an ease-of-use commendation from the Arthritis Foundation for its patented, vertical grip design that keeps your hand and wrist at a neutral angle, while the mouse works as a regular optical mouse. Grip the handle and rest your hand on the base. Use your thumb to left and right click. It is wireless and USB compatible plug and play and features optical sensor.
