It's like reaching in to the screen and holding the model in your hand
Redefine the way you work with 3D applications. Pan, zoom and rotate as if you are holding the model in your hand or fly like a helicopter through three-dimensional worlds.
Fly like a helicopter
It's a level of control that's simply not possible with a traditional mouse and keyboard. Whether you're crating dazzling 3D models or exploring vitual worlds, SpaceNavigator's superior navigation experience sets your imagination free!
3Dconnexion SpaceNavigator for Notebooks - 3D mouse - USB
3D mouse
Wired - USB
6.4 cm x 6.4 cm x 4.3 cm
250 g
Movement Detection Technology
Optical
Buttons Qty
2
Handle rotation, programmable buttons
1 x USB cable - integrated
Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 SP4, Microsoft Windows Vista, Apple MacOS X 10.4.6 or later, Microsoft Windows Vista (64-bit versions)
3D mouse
6.4 cm
6.4 cm
4.3 cm
250 g
Input Device
Wired
USB
Optical
Buttons Qty
2
1 x USB - 4 pin USB Type A
Carrying case
Software Included
Drivers & Utilities
System Requirements Details
Pentium III HD 140 MB
Limited warranty - 2 years , Technical support - phone consulting , Product info support - e-mail consulting , Product info support - web support
