The power adapter is designed to provide a consistent and reliable power output, ensuring that devices operate smoothly without interruptions.
Broad compatibility
With a voltage requirement of AC 110-240 V, this adapter can be used in various regions, making it suitable for both home and travel use.
Compact external design
The external form factor allows for easy connection and disconnection, making it convenient to use with different devices.
2-Power - power adapter - 45 Watt
Power adapter - external
128 g
Input Voltage
AC 110-240 V
Output Voltage
12 V
Power Capacity
45 Watt
8.5 cm x 3.4 cm x 2.6 cm
1-year warranty
Microsoft Surface 2, RT
Input Voltage
AC 110-240 V
Output Voltage
12 V
Max Electric Current
3.6 A
Power Capacity
45 Watt
Limited warranty - 1 year
8.5 cm
3.4 cm
2.6 cm
128 g
