The MI-7526F is a Gigabit Ethernet interface module that has 20 mini-GBIC (SFP) slots and four dual personality interfaces. It also has one slot for a 10 Gigabit uplink module.
Zyxel MI-7526F - expansion module - Gigabit Ethernet x 4
Expansion module
Plug-in module
Ports
39.7 cm x 27.6 cm x 4.3 cm
2.1 kg
Auxiliary Ports
4 x shared Ethernet 1000Base-T
GigE
Data Transfer Rate
1 Gbps
Expansion module
Plug-in module
Ports
Wired
Gigabit Ethernet
Auxiliary Ports
Data Transfer Rate
1 Gbps
Status Indicators
Power, active, status
Expansion Slots
24 x SFP , 1 x expansion slot
4 x 1000Base-T - RJ-45
Compatible Slots
1 x Expansion Slot
CSA, EMC, FCC, UL 60950-1, IEC 60950-1, EN 60950-1
