The Phaser 7100 color printer excels at producing exceptional detail and clarity on a wide variety of media - including oversize paper - providing the capabilities you need to ensure every important print job makes a strong impression.
Xerox Phaser 7100N - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
44 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
75 mm x 98 mm
Max Media Size (Custom)
297 mm x 1200 mm
Print Speed
Up to 30 ppm - B/W , Up to 30 ppm - colour
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
USB, LAN
667 MHz
RAM Installed (Max)
1 GB (2 GB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF, XPS
Media Type
Envelopes, labels, plain paper, banners, cards, recycled paper
Total Media Capacity
400 sheets
Media Handling
150-sheet bypass tray, 250-sheet input tray
Monthly Duty Cycle (max)
52000 pages
Print server - Ethernet, Fast Ethernet
UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X 10.5 or later
Environmental Standards
EPEAT Gold
1-year warranty
49.95 cm x 53.8 cm x 40.6 cm
Printer Type
Printer
Print Speed
Wired
USB, LAN
1200 dpi
1200 dpi
PostScript Support
Standard
First Print Out Time B/W
9 sec
First Print Out Time Colour
11 sec
Language Simulation
Fonts Included
82 x PCL , 136 x PostScript
Colour Management Features
PANTONE Digital Color
Media Handling
667 MHz
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
75 mm x 98 mm
297 mm x 1200 mm
Media Sizes
A5 (148 x 210 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 210 x 900 mm, 297 x 1200 mm, 75 x 98 mm
Media Weight
60 g/m² - 216 g/m²
400 sheets
Media Feeders
1 x automatic - 150 sheets - 297 x 1200 mm weight: 60 g/m² - 216 g/m² , 1 x automatic - 250 sheets - 297 x 432 mm weight: 60 g/m² - 216 g/m²
Max Media Capacity
2050 sheets
Output Trays Capacity
250 sheets
Duty Cycle
52000 pages
Print server
Network / Transport Protocol
TCP/IP, Bonjour
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
Secure Print, SSL, IPsec, 802.1x, IP filtering
IEEE 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
EMC, UL 60950-1, CSA C22.2 No. 60950-1-07, FCC Part 15 A, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC
Power supply - internal
Frequency Required
50/60 Hz
600 Watt
Power Consumption Stand by / Sleep
75 Watt
Software Included
Drivers & Utilities, Print WebJet Admin plug-in, Xerox CentreWare Web, Xerox Job Accounting, Xerox Global Print Driver, Xerox CentreWare Internet Services, Xerox Mobile Express Driver
