Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
Add additional room thermostats to rooms with radiator thermostats as a convenient way to view and change the room temperature. Works with all Wiser Kits
What makes Wiser wiser.
No wires, no installation, no mess. The wireless room thermostat is battery powered, and thanks to the handy table stand and wall clip, can be positioned anywhere.
- Wireless thermostat - no wiring, no fuss
- Multi-colour display
- Capacitive touch buttons
- Humidity sensor
- Manual temperature adjustments
- Battery life of 2 years
