Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
Two channel thermostat system with two radiator thermostats to start zoning your system. Suitable for conventional boilers with a separate hot water tank. Set schedules for the room thermostat, radiator thermostats and hot water via the Wiser Heat app. Add more radiator thermostats to create more independent zones.
What makes Wiser wiser.
Wiser makes home personalisation affordable by allowing you to start with a room thermostat and build a full multi-zone system over time by adding radiator thermostats. Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
- Multi-zoning - build the perfect system by adding Radiator Thermostats as required
- Works with Amazon Alexa
- Eco Mode - combines weather compensation & optimum stop for maximum savings
- Simplicity - standard wallplate, wireless devices
- Remote Control - simple app with boost & away mode
- OpenTherm® technology
Kit contains:
- 1 x Room thermostat
- 1 x 2 channel Heat Hub®
- 2 x Radiator Thermostats
- 1 x Thermostat stand
- 1 x Thermostat wall bracket
- 6 x AA batteries
- 1 x OpenTherm module
- 1 x Wallplate
- 2 x M30x1.5mm ring nut
- 2 x Drayton valve adapter
- 2 x Danfoss RA valve adapter
