The powerful Veho Pebble Verto Pro portable power bank is the must have accessory to keep all your mobile devices full of charge.
The Verto Pro packs a 3,700mAh that is two times the regular battery of a Apple® iPhone or Android™ smartphone, which means it will keep your devices on the go and you won't have to worry about running low on phone power.
The Pebble Verto Pro now includes an MFi Apple® Lightning cable, which is compatible with the latest iPhone®, iPod® and iPad. Alternatively, use the cable supplied with your USB power device to charge other devices such as Android™ smartphones, tablets, Sat Nav’s and many more.
The battery charger is perfect accessory for festivals, camping trips, travelling abroad or as an emergency power pack for those busy days when your devices battery just can't keep up.
Designed in the UK, the Pebble Verto Pro is packed with superior quality lithium-ion battery cells, ensuring that you get the true mAh rating and conform to all safety marks and regulations such as CE, RoHS and EMC.
The Pebble Verto Pro comes with micro-USB to USB-A charging cable, a protective carry pouch and multi-lingual user manual.
Apple®, iPhone®, iPod® and iPad® are registered trademarks of Apple Inc.
Android™ is a trademark of Google Inc.
Key Features
- Powerful 3,700mAh portable power bank that includes MFi Apple® Lightning cable, which is compatible with the latest iPhone®, iPod® and iPad
- Mini credit card sized portable design with included neoprene carry case. Perfect for handbag or pocket
- Perfect accessory for festivals, camping trips, travelling abroad or as an emergency power pack
- Ergonomic design with digital battery status indicator, designed in the UK
- Superior quality lithium-ion battery that conforms to all safety marks such as CE, RoHS, and EMC.
Box Contents
- Veho Pebble Verto Pro
- Apple MFi Lightning Charging Cable
- Micro USB to USB-A Charging Cable
- Protective Neoprene Pouch
- Multi Lingual User Manual (English, French, Spanish, German, Italian, Portuguese, Russian, Chinese & Japanese).
