It's always annoying having to turn your PC on to charge your MP3 player or iPod. Now you don't have to with the VAA-003 from Veho. Convert your USB charger cable into a UK mains charger plug! If you only have a USB lead to charge your Muvi, 360 speaker or iPod device then it's frustrating having to turn your PC on just to power it up. Simply plug the USB charger/sync lead into the USB converter and then plug into the wall to start charging.
