The rugged water resistant smartphone case features the patented Pinnagrip system which enables the S6 to grip, hold and protect most varieties of smartphone. Attach it anywhere using the supplied karabiner or to your handlebars using the optional handlebar mount. The unique Pinnagrip system means that a large majority of smartphones fit inside and are held firmly in place meaning the SAEM S6 is future proved for when you change your phone.
