The 2-Port USB Audio KVM Switch lets you control multimedia PCs with just one keyboard, monitor, mouse, microphone, and a set of speakers. The KVM switch not only allows you to share your monitor, keyboard and mouse but you can also share microphone and speakers. With just a simple press of a button, this KVM switch eliminates the hassle of cable swapping and switching between 2 PCs. With it's Hot-Plug, Auto-Scan and Hot-Key operating features, the TK-209K is the perfect choice for managing 2 PCs. Separate KVM cables are included.
Control up to 2 computers/servers with one set of console device
USB keyboard/mouse emulation with 2 sets of detachable KVM cables
Compliant with Windows, Linux and Mac OS.
High video quality, up to 2048 x 1536 VGA resolution
Listen to music from one computer while working on the other
Auto-Scan & LED display for computer monitoring
Computer selection by face panel push buttons, keyboard hot key commands or Windows-based client switching software*
User definable hot key (Windows only)
Plug & Play and hot-pluggable
USB interface power method
2-year limited warranty
