Based on the Powerline technology, your network extension is never limited to the primary coverage of your router. Using your existing electrical wiring, this kit brings network to anywhere there is a power outlet. You can easily create a dual-band Wi-Fi network (simultaneous use of 2.4 GHz and 5 GHz bands) with more bandwidth and less interference, maximizing the performance of your Powerline network. A unified network allows you to stay connected, even when you're on the go. You can enjoy a single, seamless network throughout your entire home or office, without having to switch from one hotspot to another.
