Balance of Speed & Storage Capacity
Ideal for PCs and Console Gaming
500GB
8GB MLC NAND
5400rpm
64MB Buffer
SSD-Like Performance and HDD-Like Capacity
Toshiba's SSHD recorded the score of PCMARK® Vantage several times higher than the conventional HDD.
Optimized self-learning caching algorithm
Toshiba's SSHD dynamically learns the access pattern in each system and directs data to the appropriate tiers, that are DRAM, NAND and disk media. High speed access is achieved by storing frequently-accessed data to NAND.
NAND flash memory controller technologies
Toshiba also develops leading-edge microscopic memory technology in NAND. This experience enables Toshiba to boost the NAND technologies, such as defective blocks management, ECC (Error Correction Code), conversion of logical block address, and wear-leveling.
Cost Performance
Toshiba's SSHD is a lower cost alternative to SSDs while keeping close to SSD performance by the optimized NAND configuration.
High Anti-Oscillation Performance with RV Sensors
As a feature engineered to raise performance and reliability, an RV sensor detects increased vibration to help curb the impact of such shaking.
