Operate a PS/2 & VGA KVM or PC up to 500ft away as if it were right in front of you. The SV565UTPGB PS2 KVM Console Extender Cat5 Extender (500 ft) lets you control a server, computer or multiple computers (connected through KVM Switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 500 ft (150 m) away.
Use your existing keyboard, mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
For added convenience, the Console extender is compatible with any brand of PS/2 KVM Switch.
