Connect an eSATA storage device to a USB 3.0 port on your laptop or desktop. The USB3S2ESATA3 USB 3.0 to eSATA drive cable lets you connect any eSATA hard drive, solid state drive, or optical disc drive to your USB-enabled computer system - a great solution for computers that don't natively support eSATA, such as MacBook and Ultrabook computers.
To maximize performance and utilize the speed potential of your SATA 6 Gbps drives, the USB 3.0 to eSATA adapter is compatible with SATA revisions I/II/III and supports transfer speeds up to 5 Gbps through USB 3.0.
With support for Blu-ray/DVD/CD ATAPI / ODD drives and large capacity HDD / SSDs (tested up to 4TB) the USB to eSATA adapter cable is compatible with virtually any eSATA device, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0 to eSATA drive cable ensures a hassle-free connection with simple plug-and-play installation, plus the cable is the perfect length (1-meter, end-to-end) for easily accessing the rear panel USB ports on your computer.
