Mount a display on your desk surface or through a grommet, with gas-spring height adjustment and cable management. The ARMPIVOTE Articulating Monitor Arm lets you mount a display to your desk or table, with extension, tilt, pan, swivel, pivot and gas-spring height adjustments.
The desk-mount monitor arm features a gas-spring cylinder to raise or lower your display with minimal effort, plus it offers a wide range of motion on several axes. For viewing longer pages or blocks of code without scrolling, the LCD arm also supports landscape to portrait display rotation.
Mounting your displays on a monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 11lbs (5kg), the monitor mounting arm holds your display with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile monitor mounting solution.
StarTech.com Monitor Mount w/ Articulating Arm -...![]() In Stock £163.28 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0In Stock£67.48 |
StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk MountIn Stock£64.11 |
StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable HookIn Stock£55.46 |
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting KitIn Stock£73.16 |
StarTech.com Articulating Monitor ArmIn Stock£101.86 |
StarTech.com DVI Laptop Docking StationIn Stock£66.45 |
StarTech.com 4K DP Laptop Docking StationIn Stock£99.36 |
StarTech.com USB-C Multifunction Adapter 4KIn Stock£54.49 |
StarTech.com Monitor and Laptop ArmIn Stock£87.11 |
StarTech.com USB-C Multifunction AdapterIn Stock£60.65 |
