The ARMPIVOT Adjustable Monitor Arm lets you mount a display to your desk or
table on a simple yet stylish monitor pole, with tilt, pivot and height
adjustments.
The desk-mount monitor arm features an 11.89in (302mm) tall support post,
for a much greater height adjustment range than a typical monitor stand can
provide. For viewing longer pages or blocks of code without scrolling, the
LCD arm also supports landscape to portrait display rotation.
Mounting your displays on a support post above the desk surface enables you
to adjust your display height, position and viewing angles easily for an
ergonomic work environment, with the added benefit of reclaiming valuable
workspace on your desk.
Supporting 12 - 30" displays up to a maximum weight capacity of 30lbs
(14kg), the monitor mount holds your display with ease, and integrates a
cable management hook to keep things neat. For added installation
flexibility, the included mounting hardware can either clamp to the side of
your desk, table or mount through a grommet hole.
