The dual-drive duplicator and eraser is ideal for IT professionals, such as system administrators and technicians, because it makes drive management more efficient. The drive duplicator function is effective for disk image duplication, data recovery from failing hard drives, and backing up and archiving hard drives to prevent data loss. It provides standalone sector-by-sector hard drive cloning with up to 24 GBpm or 420 MBps duplication speed. You can duplicate 2.5" or 3.5" SSDs or HDDs with ease, without connecting to a host computer.
Two erase modes
The erase function helps you get the most out of your SATA drives, making it easy to re-use or re-purpose your drives. The drive eraser securely sanitizes up to two drives simultaneously, providing two modes of erasing: quick erase and secure erase. The secure erase mode provides you with the peace of mind that sensitive data has been sanitized, important to many businesses, government offices, and professional services such as legal, accounting and health care offices.
Transfer files quickly between the dock and your PC
The dock also provides an external storage solution, letting you dock your drives through USB 3.0 (5 Gbps), also known as USB 3.1 Gen 1, and transfer files between a docked hard drive and a host computer. It improves your workflow by providing quick access to your hard drives, with the ability to easily swap drives in and out as needed.
Includes two USB cables for versatility
The drive duplicator and eraser comes with two USB cables, for flexible use with the latest USB-C laptops and tablets, as well as legacy devices. It includes both USB-C to B and USB-A to B cables. The duplicator dock is also compatible with a Thunderbolt 3 USB-C port.
Designed for easy drive management
The dual-drive duplicator/eraser features a top-loading design that makes it easy to insert your drives. It also features independent drive doors, drive controllers and power switching. The ejection buttons enable fast and simple drive removal. LED indicators display the current state of the duplication or erasure process, including the HDD status and clone or erase progress.
StarTech.com Dual Hard Drive Duplicator And Eraser - HDD sanitizer - Hard Drive Dock (SDOCK2ERU33) - solid state / hard drive duplicator/eraser
