Connect two DisplayPort monitors to your DMS / LFH-equipped graphics card. TheDMSDPDP1DMS-59 to Dual DisplayPortCable allows you to split the video from a single LHF graphics card on to two DisplayPort (DP) monitors.
The DMS to DP Y cable supports high resolutions of up to 4k x 2k (3840 x 2160) with a maximum HBR2 bandwidth of 21.6 Gbps and iscompatible with DMS / LFH 59or DMS / LFH 60graphics cards such as Matrox, NVIDIA, PNY, ATI and HP.
The DMSDPDP1 is designed and constructed for maximum durability - making it a reliable and cost-effective replacement for damaged or misplaced DMS to 2x DisplayPortcables.
