Add 3 external USB 3.0 ports with UASP and a Gigabit Ethernet port to your Ultrabook or laptop through a single USB 3.0 port. The ST3300GU3B Portable USB 3.0 Hub features an integrated GbE port, enabling you to expand your laptop connectivity by adding three external USB 3.0 ports, as well as a Gigabit network port via a single USB 3.0 connection. This hub is an ideal laptop accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface Book, Dell XPS 13, and many other devices.
The hub merges Gigabit network support and USB 3.0 hub access into lightweight yet sturdy aluminum casing, providing vital connectivity ports that are often limited or nonexistent on modern mobile computers, while remaining compact and travel-friendly. Plus, with an attached USB 3.0 host connection cable there's no need to carry a separate cable with you, so you can tuck the hub neatly into your laptop bag for maximum portability.
For faster and more consistent network connections, the integrated Ethernet port leverages the 5 Gbps capabilities of the USB 3.0 interface to provide wired Gigabit access that is fully compatible with IEEE 802.3/u/ab standards.
An ideal laptop accessory, this mobile USB hub is great for connecting low-power peripherals like a mouse, keyboard or USB flash drive, and also includes a universal power adapter for connecting devices.
StarTech.com 6 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch CableIn Stock£3.36 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£22.95 |
StarTech.com 6 ft Black SuperSpeed USB 3.0 Extension Cable A to A - M/FIn Stock£6.16 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/FIn Stock£5.78 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - WhiteIn Stock£36.03 |
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£17.59 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in CableIn Stock£15.24 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - BlackIn Stock£25.96 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - WhiteIn Stock£25.96 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 PowerIn Stock£18.76 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps ChannelsIn Stock£72.27 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA PowerIn Stock£21.47 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – BlackIn Stock£38.18 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ CableIn Stock£36.58 |
StarTech.com DC Power Adapter - 5V, 2AIn Stock£9.12 |
