Charge or sync your Apple devices, even when inside a protective case. The USB2ADC1MB 1-meter Apple 30-pin Dock Connector to USB cable for iPhone, iPod and iPad is colored to suit black mobile devices and provides reliable connectivity of your iOS-enabled mobile digital devices to your computer, for syncing and charging.
Plus, this uniquely constructed Dock Connector to USB cable features a stepped Apple Dock Connector, designed by StarTech.com, which unlike a regular connector plugs into your iPhone, iPod or iPad, even when inside a protective case while avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
