Print wirelessly and share effortlessly with the Samsung Xpress printer. With advanced NFC technology, Wi-Fi Direct and powerful compatibility, all it takes is a simple tap.
Text, graphs or images - the C410W helps you print anything in brilliant quality that meets even the highest expectations. Its 600 x 600 dpi can be enhanced to an impressive 2400 x 600 dpi by varying the dots size and the position of the dot itself. This means you can print more detail and have smoother and sharper images.
