Back
Speakers
Samsung TSST Bluetooth Speaker 6W - Grey
Quicklinx:
BFWKWS00
Mfr#:
TS006BA/EUAT
Back
Marketing description is not available.
TSST TS006BA - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
6 Watt
Frequency Response
150 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - stereo x 2 - 3 Watt - 150 - 20000 Hz - 0.1% THD - active
Dark grey
Built-in Decoders
SBC decoder
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
12.4 cm x 2.5 cm x 6.8 cm
187 g
Enclosure Colour
Dark grey
Speaker System
Speaker Type
Active
Continuous Power
6 Watt
Frequency Response
150 - 20000 Hz
Max Output Level (Max SPL)
90 dB
Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Low Complexity Subband Coding (SBC)
Built-in Decoders
SBC decoder
Controls
Power on/off
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 3 Watt - 150 - 20000 Hz CFR - 0.1% THD - active
Driver Details
Speaker: 2 x full-range driver - 1.5" - neodymium
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
USB cable, flip cover
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
750 mAh
Run Time (Up To)
10 hour(s)
12.4 cm
2.5 cm
6.8 cm
187 g
