Images come to life on the screen with stunningly natural colors: the even richer color gamut allows for greater appreciation of details while reducing power consumption.
HDR
View images with detail as in the real world. Live the true HDR experience characterized by deeper blacks and brilliant whites.
UHD Resolution
Enjoy all the realism down to the smallest details with UHD TV's 4X resolution. Content will look even more pleasing with incredibly lifelike colors and brightness.
Auto Depth Enhancer
Discover excellent dimension and get caught up in the viewing experience: the Auto Depth Enhancer function adjusts multi-level contrast levels to optimize the feeling of depth.
360° Design
Admire it from every angle. On or off, the TV with 360° Design blends seamlessly with any décor thanks to its minimal profile and clean backside configuration.
Wonderful curved profile
Bring out all the beauty of the curved profile. Taking its cue from the lines of nature, it embodies pure elegance, on or off.
One remote control
All controls at your fingertips. Manage all your devices using one remote control. Thanks to voice command, you no longer have to scroll through channels in circles.
Smart View
Connect your smartphone to the screen and enjoy all your favorite content. With the Smart View app, you can easily manage everything from your smartphone.
Samsung UE49MU6500U 6 Series - 49" LED-backlit LCD TV - 4K
Curved LED-backlit LCD TV - Smart TV
Diagonal Class
49"
Silver
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
1600 Picture Quality Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN, Bluetooth
LCD Backlight Technology
LED backlight UHD dimming
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Picture Enhancements
Digital Clean View, Mega Contrast, Ultra Clean View, UHD Upscaling, Accessibility High contrast, Auto Depth Enhancer, Active Crystal Colour
Speaker System
2 speakers
USB
2 ports
Samsung TM1750A remote control, batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
150 Watt
Power Consumption (On mode)
90 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
125 kWh
109.47 cm x 10.42 cm x 63.81 cm
14.2 kg
Curved Screen
Yes (3000R)
Energy Class
Class A
150 Watt
90 W
125 kWh
Diagonal Class
49"
Series
6 Series
HDR Capable
Video Processor
Quad-Core
TV Tuner
TV Tuner Presence
Extended PVR
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
3 ports
Modes
Game mode, Film Mode
Design
Very Narrow Bezel Design (VNB), Y-Shape Design
Dimensions
Without stand
109.47 cm
10.42 cm
63.81 cm
14.2 kg
Enclosure Colour
Silver
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Display Menu Language
Multilingual
Time-shift, HDMI quick switch, Auto Motion Plus, E-Manual, Instant On, Embeded POP, Accessibility Enlarge, Accessibility Voice guide
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Samsung TM1750A
Additional remote control included, Samsung Smart Control included
